Oil pan removal using no shop lift, how hard is it?
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
So i built my new motor and now the oil pan gasket is leaking badly. Throwing out the chrome pan and bought a Morso OEM replacment pan. Going to start on it this weekend, but since I cant use my shop hoist, I have to do it at home on my back. How much of a PITA will it be? Im guessing ill have to undo at least 1 motor mount and jack the motor up for removal?
Car: 2005 GTO
Engine: LS2
Axle/Gears: 3.73 LSD
Re: Oil pan removal using no shop lift, how hard is it?
Going to be a little bit of a pain since you'll need to remove the jack to get the oil pan out.
Will have to support the engine somehow. Maybe blocks of wood on the mounting brackets?
Engine: Vortec 357
I think im going to use my cherry picker to keep the engine up so that I have nothing in my way underneath.
Car: To many to list
Its not really a hard job,pretty straight forward. I pulled both motor mount bolts and put blocks of wood in between them. I think I may have removed the dist cap also..IIRC
Navy8125
Aug 21, 2015 09:32 AM
