car is touchy to start
Car: 86 Trans am
Engine: workin on a 383 for it!
ok this seems a little odd with my car, it seems like my vehicle has to atleas set 15 min after it's been shut off before i can get a guaranteed start, but if it's cold or wet it just dosent really like to start or I kill the battery trying to start it any ideas?
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: car is touchy to start
Need more info but i have a strange suspicion this is a carbed car right? If thats the case i suspect maybe a tuning issue or maybe a problem with the choke or even a vapor lock condition. If im wrong and its injected which i probably am my guess is ide start by checking out your ignition system. The distributor if wet can be very temperamental if it gets wet inside and the ignition modules are know for issues with heat. Any check engine codes?
Car: 86 Trans am
alright well im going to have it in the shop by next week to take a look at it, and probably change manifolds so we will see what hapens as long as the weather hopefully will let up a little?
