how to make more power from a 305
Old Feb 10, 2010 | 12:17 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
ok so my 87 iroc has a early 80s 305 in it but has a rod knock. My buddy gave me a 305 from a 91 caprice with the center bolt valve covers, it only has 65,000 on it so im going to use it for now until i finish building my 350 motor which wont be done till next winter. So i just wanna know a few mods to get some hp from it besides headers. It has 3inch exhaust on it with a flowmaster. Its going to be a carb motor, 650cfm holley with an edelbrock performer intake manifold. Anything else i can do with out doing a cam and touching the bottem end.
Old Feb 10, 2010 | 04:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: how to make more power from a 305
I'm not sure if that uses a roller cam or a flat tappet cam, but i'd highly re-think your choice of not touching the cam. It's so painfully tame in the caprice that you can't help but improve it. $200-$300 or so, and the difference is massive.
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
A 100 shot. Seriously.
My daughter's 86 LG4 with TPI exhaust and 3.73 rear has gone 13.1's with a 90 shot. Looking for 12's next time out with the S-10 converter.
Old Feb 10, 2010 | 05:26 PM
budget350's Avatar
Car: 87 iroc, 91 rs
well i just through back my gm performance parts crate engine and hopefully it runs. Its a 350 btw. The 305 is a back up. If it runs ill keep the 350 in it, if it dnt then **** happens n 305 goes in.
Old Feb 14, 2010 | 02:34 PM
64elko's Avatar
Car: 64 elcamino
hello say what this i read about useing a s-10 converter can you explane
Old Feb 15, 2010 | 08:43 AM
86LG4Bird's Avatar
In the case of the 86 LG4, the stock torque converter has about a 1400 rpm stall rating, which, in very simplistic terms, means that until the car starts to move, the engine is held to 1400 rpm. Naturally, this is far below both the torque and horsepower peaks of the engine, and acceleration off the line is very limited. The factory-installed converter in the S-10 pickups has a stall rating in the 2000-2200 range and is a big improvement in letting the engine snap to near its peak torque rpm, getting the car off the line more quickly, resulting in improved 60-foot times and ET's. This of course assumes you have adequate traction/tires/track prep. Then there is a further benefit with each gear change, as the engine doesn't fall as far below its power peak after each shift.
I'm guessing the TC change will result in a 60' improvement on this car of .05 to .10 sec, which translates into a .1 to .2 second improvement in ET.
Old Feb 15, 2010 | 11:53 AM
64elko's Avatar
Car: 64 elcamino
hello
thanks for the info...
i have a 64 elko with a 700r4 in it ,,so this is still ok for streetablity for day driving....
mr elko
Old Feb 15, 2010 | 11:58 AM
86LG4Bird's Avatar
hello
mr elko
Yes, the S-10 converter is barely noticeable in part-throttle daily driving.
And most people even consider stall speeds in the 3000-3600 rpm range acceptable in daily driven light vehicles like 3rd Gens.
Old Feb 16, 2010 | 09:10 AM
101btp's Avatar
Car: 86 Trans am
Engine: workin on a 383 for it!
ya just make sure the engin4e is set up for nos lol
Old Feb 16, 2010 | 10:59 AM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
This, 305s were efficiency motors from the factory. They're almost all cammed like diesel engines. A LT1 cam will wake it up massively (if it's a roller engine).
jaridjohn
Jul 8, 2024 03:49 PM
jhawkeye
May 25, 2022 06:33 PM
Reborn756
Sep 4, 2015 03:42 AM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
