stalling problem
Old Feb 5, 2010 | 09:14 PM
Shiner81's Avatar
stalling problem
Hello,
i have an 87 IROC 5.0 TPI with a T-5. I bought this car with a spun rod bearing a year ago and have finally got it running. now i'm having an issue with it stalling. If i down shift coming to a stop which i normally do with any stick shift it will stall when i downshift to first and push in the clutch and brake. if i don't downshift at all and let the brakes stop the car completely then it drops down to idle and is fine. there are no SES lights no codes no nothing and i am lost at possible causes here. other then this problem the car runs like a champ. thanks for any and all help you can give to get this issue fixed. thanks
Dave
Old Feb 5, 2010 | 09:51 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: stalling problem
might have a sluggish IAC valve?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
92camaroJoe
Aug 13, 2015 06:07 AM
