help me finish swap please
Old Feb 10, 2010 | 10:50 AM
matts86cam's Avatar
Car: 1986 chevy camaro z28 coupe
Engine: crate 355
Transmission: 700r
swapped 305 carb'd to 355 carb'd
2 questions:
1. distributor;
do i have to have an advance? same stuff that was hooked up before is hooked up now and the 305 ran great (just had some bad rings), should i get a vac advance distributor and hook it into the front of the carb (edel. 650 with one big port in middle and 2 small ones beside it) of will it damage the engine if i dont?
2. exhaust manifolds bolt on to the 355 block but i cant bolt them into the y pipe. it doesnt seem like the the y pipe is long enough. the new engine has a 7 quart pan on bottom but it doesnt seem to be in the way. is there just sand in my mangina or is the 355 set a little higher? I had stock heads before and have 1st gen vortec heads now but they look the same height gonna cut it and put a patch in i guess.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
