Cometic MLS gasket
Old Feb 12, 2010 | 04:35 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Cometic MLS gasket
So I got some custom made cometic MLS gaskets for my 412. 4.200 x .030".
So anyhow, there idea of an MLS gasket is 3 shims, riveted together in three spots.
Kinda weird.
Any thoughts ?
-- Joe
Old Feb 12, 2010 | 04:59 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Cometic MLS gasket
Any idea what the final compression will be?
Aluminum heads?
I was thinking MLS for the Bigblock build, but thought since we're using the iron heads there wouldn't be any benifit because it'll be iron heads to iron block-- no diff in heating & cooling of block//heads.
Post up how they work for you!
Old Feb 12, 2010 | 05:02 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Aluminum heads?
Gonna be 10.81:1 with alum afr heads.
These rivets are kinda freaking me out. I'm tempted to drill them. Why would they rivet the gaskets together.
-- Joe
Old Feb 12, 2010 | 05:18 PM
Car: '87 Camaro
Is that an option to get rid of?? If they hold the ply's together, how would that affect the " movement " around the bores//water jackets?
( edit )
I would think the rivs wouldn't cause a problem-- aren't they out side of the head//block mating area?
I miss my '74 Camaro : (
Old Feb 12, 2010 | 05:20 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Dowel pins on the deck should center the gaskets i'd think. ?
This is my third 2nd gen.. I had a 79, a 78, and now another 79. I like the interior, the 'style'. I'm put off by how much the car weighs. You need another 100hp to run the same ET and MPH as a thirdgen.. Lame huh?
Unfortunately, with mortgages, horses, etc I can't afford the '67 Camaro I really want to build
-- Joe
Old Feb 12, 2010 | 05:37 PM
Car: '87 Camaro
I believe rivets may be holding the assembly in a way that allows the expanding//contracting of the MLS to be more controlled.?.?
Did you get copper or composite?
Old Feb 12, 2010 | 06:11 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I use a MLS gaskets on my engine. Buy some copper spray and coat both sides of the head gasket. You can reuse the gaskets as many times as you want unless you somehow damage them. It's the last head gasket you'll have to buy.
MLS = Multi Layer Steel. They're riveted together because it keeps them lined up as a set. The rivets should not cause interference anywhere in the installation.
Old Feb 12, 2010 | 06:22 PM
Guest
Guest
Posts: n/a
The rivets are just there to keep the 3 pieces aligned. You can and may have to remove them, I had to remove mine. It was also very difficult to get the gasket on, the holes for the dowel pins are exactly the right diameter so you may have to do what I did and slightly elongate one hole. It may be that the dowel pins on my block were that few thousandths off. Not sure what the story is, but thought I'd mention it.
My machinist told me to use the Permatex high tack spray rather than copper coat on them so thats what I did. So far I am very pleased with them.
Old Feb 12, 2010 | 09:30 PM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Wow. Well. We've got some opposing opinions here.. darn..
I expected a felpro type MLS gasket, you know, like metal shims compressed together with a synthetic. But that is fine.. I'm concerned with a couple things:
1) I don't know wtf a 'surface roughness of 50' is..
2) The block was decked. It had been rusty, and the deck surface has some pits. A normal gasket I'd think would be ok with that.
3) I had some flash rust on the deck surface overnight in a small spot behind #7 and #8, even with the bag on. Oiled it down. WIll probably just rub it out with emory cloth, but still.
4) I'm not convinced the rivits won't either hang the head up, or just screw up the head surface..
I've heard good and bad things about cometic. Some google searches revealed a lot of water leaks with the ford guys.. I'm a bit worried over these $200 gaskets
-- Joe
Old Feb 12, 2010 | 09:57 PM
Guest
Guest
Posts: n/a
Well after visiting their website I can say they changed the gasket because it says theres a .001 viton rubber layer on the shim and the shims on mine were bare metal.
I cant remember where exactly the rivets were, but the lower one was in conflict with the block. I think the others are near the edges of the lifter valley and those IIRC hit the block as well. I cant remember if I asked them or it was in some instructions the gaskets came with, but the rivets are not needed on an assembled motor. I think I probably asked them because it was made pretty clear the surface absolutely has to be flat. Unlike a composite gasket that can essentially flow when compressed during install and fill voids, the metal shims will not do that.
Cant tell you on the roughness, has to do with the surface finish. The guy that I had machine my block and heads has a really nice CNC machine for engines and parts and finished both accordingly. I cleaned it, sprayed the gaskets (both sides) and assembled it.
Old Feb 12, 2010 | 11:36 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Not a problem with mine, and I did reuse them with copper rtv spray on both sides. The rivets are outside of any clamping area.
Old Feb 13, 2010 | 06:25 AM
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
I guess I'll call them Monday and see what they say. I guess I'm just not all that convinced the heads will compress the rivets without the rivets ruining the heads or hanging up the gasket.
I'm only used to the felpro type MLS, which is 1 peice with a fire ring.
Thanks for the insight guys. My heads won't be here until the beginning of march (AFR = slooooow) so I've got some time.
Thanks again.
-- Joe
Old Feb 13, 2010 | 03:38 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
the rivets should be on the outside of the deck. They shouldn't interfere with the heads. I built hundreds of motors with cometics and assembled them dry and never had any comebacks.
Old Feb 14, 2010 | 12:51 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I had a set and the rivetted portion was also outside the block/head surface. I had no interference problems.
db057
Jan 10, 2020 08:55 PM
sheachopper
Jul 31, 2019 11:27 AM
TP355Z
Exterior Parts Wanted
Oct 21, 2015 01:05 AM
Jonas Earl
Sep 27, 2015 07:39 AM
hdis2002
Sep 8, 2015 02:52 PM
