My engine build
Old Feb 13, 2010 | 11:22 AM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
My engine build
ok, 98% set on my build now...
pocket ported 882s with summit brand .550 lift springs, heads milled maybe 1-2cc off
2 bolt main 350 bored .060 over with forged trw pistons with .100 domes and polished crank, maybe some grade 8 main bolts
PAW deluxe budget rebuild kit with felpro, high volume pump and double roller chain, and a set of clevite cam bearings
600cfm holley carb with a dual plane intake
just gatta decide on a cam, im ganna get a summit cam/ lifter combo, but cant deciede between
.465/.488 224/234
.488/.488 234/234
.488/.510 234/244
Old Feb 13, 2010 | 12:51 PM
Car: 98 z28
Engine: ls1
Transmission: t56
Re: My engine build
called comp and they recommended 224/224 .470/.470 or a 230/230 .480/.480 so would this make the .488/.488 234/234 too big for my build?
he said a 236/236 .490/.490 was too big unless i used a 3000 stall
Old Feb 13, 2010 | 04:20 PM
Car: 98 z28
Engine: ls1
Transmission: t56
Re: My engine build
ok, did some more research and i think the prob with having a big cam is dynamic compression... so if i get the compression up to 10.2:1 and advance the timing 4 degrees, ill have a dynamic compression of 8.0
Old Feb 13, 2010 | 04:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: My engine build
What are you planning on doing with the car?
Old Feb 13, 2010 | 05:39 PM
Car: 98 z28
Engine: ls1
Transmission: t56
Re: My engine build
once the motor is done im ganna start looking for a 2nd gen for my dad... he had a 74 as a kid so i figured this would be the ultimate bday gift... he wants a summer weekend car with a mean idle and he claims he trusts me to do the rest lol
Terrell351
Jun 13, 2021 01:13 PM
italiano67
Dec 11, 2016 09:21 AM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
