mystery oil leak?
Old Feb 13, 2010 | 02:29 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
mystery oil leak?
hey guys. ive been having an oil leak for about 6 months and it pisses out pretty good. its coming from the starter area or above and i can figure out where. i just recently did a HSR intake swap and i thought it was the old intake. ive done valve cover gaskets on it and just checked it to find no fresh oil. i put it up in the air and its to soaked with oil to figure out where the source is even after i clean it.
what else could i look at that might be it. ive got every single little oil leak taken care of and then about a month later this one started.
its a 90 formula, auto with a 5.7 tpi
thanks guys. this oil leak is really ticking me off.
Old Feb 13, 2010 | 03:51 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: mystery oil leak?
Pull the torque converter cover off (Black plastic connected to the front of the tranny 4 10mm bolts) . If there is a puddle of oil chillin in the bottom, unfortunately you blew a rear main seal. Only way to get that replaced is to pull the tranny off :/
Old Feb 13, 2010 | 11:23 PM
Car: 90 formula
Transmission: auto
i totally forgot about that. and to make it even shittier is i just replaced the tranny.
i dont even think theres a cover on there.
Old Feb 14, 2010 | 11:05 AM
ZimGTA's Avatar
Car: 88 GTA
Engine: 383
Transmission: 700 r
Maybe the dipstick tube is leaking?
Old Feb 14, 2010 | 11:20 AM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
or could be a bad oil pan gasket. I have the same leak and my motor only has 2k on it. I have a chrome oil pan and i know that is part of the problem.
Old Feb 14, 2010 | 11:21 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
x2 that is my guess...
If its a rear main seal it will be sprayed across the ground like someone used a spray bottle. Also I doubt its the rear main because its on the side of the motor not the rear.
Old Feb 15, 2010 | 09:59 AM
Car: 90 formula
Transmission: auto
id have to say your right with dipstick tube.
its above oil pan or i would have changed it out. thanks guys!
Old Feb 15, 2010 | 11:46 AM
Car: 90 formula
Transmission: auto
ive replaced the dip stick it self and i bet the tube that came with it is in the dump somewhere because i thought id never need it and wanted to make space in the garage.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
