Gas Tank - EFI vs Carb?
Old Feb 15, 2010 | 10:30 AM
faubertt's Avatar
Hi Everyone - Much to my disappointment this weekend after removing my gastank I found a series of pin holes (most likely my fault for grinding the rust off it to prep it for a coating of POR 15). Either way it felt like it had a weak neck and long story short I tossed it to the curb rather than fix it. Now to the question...
I see on summits site there is two gas tanks for our vehicles..one for efi and one without...links seen below. I am running a carb now and have some new prebent lines from inline as well. What is the difference between the two? If I get the one for the carb will my float and sending unit not work since those pieces are from when my car was a fuel injected v6?
http://www.summitracing.com/search/P...yword=gas+tank
Thanks for the input...to me a gas tank should just be a gas tank
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
mustangman65_79
Sep 1, 2015 03:51 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
