Erratic / High Idle - Solved
Old Feb 15, 2010 | 05:16 PM
Curious_George's Avatar
Car: '87 IROC, '92 & 99 Corvette Vert.
Engine: L98, LT1, LS1
Transmission: L98 = 700R4
Axle/Gears: L98 = 3.23 G92
I finally solved an erratic high idle problem that I have been having for sometime. Stock '87 305 TPI, A4; Symptom - Ocassionally, after start-up and stopping at lights / stop signs, the engine would idle high (1500 RPM) and then come back down to a normal idle. I connected my laptop and used TunerPro to scan data. When the idle started to go high, I noticed the IAC steps going up slowly (as assumed / predicted). I also noticed my TPS voltage going up slightly as well.
In a nut shell, the TPS voltage that was creeping up, made the IAC steps increase, thus increasing my idle. Previously, I had replaced the TPS for preventive maintenance. My TPS connector / pigtail looked pretty boogered up too (original connector), so I bought a new TPS pigtail and went back to my OE TPS sensor (reset TPS voltage) and the idle is now back to normal. It is amazing how a high idle can drive you crazy! Not only knowing that something is wrong, but the drivibility of the vehicle stinks. Now, it is so much pleasurable to drive.
CG
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
