Weird Motor Problem!!!
Old Feb 16, 2010 | 07:32 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
Hi i have a question on what can be causing my car to do this..1987 iroc with 305 tpi...when the car warms up and is in drive the car will like go up in idle and come down when i let off the gas it not like alot but its noticeable..it will go maybe from the 5 to the 10 in rpms and shoot up real quick and just come down what can be causing this..im sorry if its not the best explanation but its hard to explain it..its like if ur stepping on the gas and letting go real quick...any help would be great thanks.
Old Feb 16, 2010 | 09:23 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Weird Motor Problem!!!
The number one cause of a surging idle is a fault in the EGR system. May want to tear down the intake and inspect/clean the EGR valve itself as well as check out the rest of the system.
Old Feb 16, 2010 | 10:39 PM
Engine: 350 tpi
well ima be doing that soon then cause my intake manifold gaskets need to be replaced ill be sure to check that out. thanks.
Ghettobird52
Jul 5, 2024 11:18 PM
jhawkeye
May 25, 2022 06:33 PM
Cleotiz
Jan 6, 2018 08:56 PM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
