crank machined and endplay question
Old Feb 17, 2010 | 12:28 AM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
I had my 305 bored and crank turned .010 and this is my first build for my own engine. Just installed bearings and checked clearances with plastiguage and everything was in spec. Torqued the main caps and set up the dial indicator to measure endplay. spec is .002'' to .006''.
My endplay is .007''.
should I bother to correct this and how would i go about doing so?
Also should I have the oil pump installed when checking clearances?
I think it will be fine but just need a second opinion from someone has built a few more engines than me.
Old Feb 17, 2010 | 12:34 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: crank machined and endplay question
I wouldn't worry about an extra .001" of endplay. There's not a lot you can do about it anyway. Measure the clearance on the rear main with the oil pump bolted in place and torqued down.
Old Feb 17, 2010 | 12:45 AM
Engine: 305 tpi lb9
Axle/Gears: 3.45
what if the oil hole doesnt line up exact with the thrust bearing is that a problem at all? its a little bit off.
Old Feb 17, 2010 | 04:54 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
grind it very carefully/debur and clean real well.
Caspar
Jun 19, 2016 11:19 PM
Cameeeero
Sep 18, 2015 04:00 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
