High Flow TPI Install, Now wont idle
Old Feb 17, 2010 | 10:51 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I just installed a TPIS Bigmouth Intake manifold and a set of TPIS/AS&M runners on my car and now the car will start right up and die. It will try to stay running if you give it gas but it still won't run like it should. My question is can it be stalling because I didn't make any changes to the PROM or is it likely that I purchased a set of the AS&M runners with the warped flanges?
Old Feb 18, 2010 | 06:44 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
Re: High Flow TPI Install, Now wont idle
well there could be a few things that come to mind. First off, I'm assuming that all of the sensors and vacuum lines are connected properly. Did you disconnect the battery during this process? You should attempt to set the IAC according to factory specs. If this doesn't correct the issue I would check for possible vacuum leaks. Normally you will not have to make corrections in the chip for the replacment of an intake especially on a MAF car. They are reasonably forgiving as far as replacing intake bases and runners. I'm not stating that this is absolutely not your problem but I would think you should be ok. I noticed there are quite a few mods listed as far as the cam etc, were these already installed before the intake swap? or did you add all of these components at once?
Old Feb 18, 2010 | 07:01 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
You have a vac. leak
Old Feb 18, 2010 | 11:41 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Well I finally got the car back to running again. I can now tell that I have a vacuum leak. It sounds like it could be coming from the 9th injector. I guess my MAF sensor is bad also because the car will now stall when it is plugged in but will stay running when unhooked. Those other mods were already installed before this inatke swap.
Old Feb 20, 2010 | 07:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I still can not find the vacuum leak on my car. It sounds as if it is coming from around the 9th injector area. Any suggestions on where it might be coming from?
Old Feb 20, 2010 | 09:16 PM
1970 Buick's Avatar
Car: 1989 GTA
When I installed my Accel LTR's it ran like crap. I had a guy look at it and he ended up having to epoxy a tube in the driver's side runner. It was a tiny tube going up one of the runners but there was no hole in the manifold for it to draw air from. That is what happened with mine, a nasty vacuum leak.
Old Feb 20, 2010 | 10:24 PM
larrybldr@gmail's Avatar
Car: 87 GTA 5.7 / malibu prostreet
Engine: 5.7 TPI SLP PACKAGE
Axle/Gears: 9 BOLT(AUSTR) 3:70 GEAR
I WOULDN'T JUMP TO CHANGE THE MASS=AF TO QUICK. iT'S PROB GIVING THE COMP A FALSE READING DUE TO THE VAC LEAK... SOUNDS LIKE THE BASE INT GASKET OR THE RUNNER TO BASE GASKET.. HOW ABOUT THE O-RING ON THE NINTH INJ? MISSING??? i HAVE A 87 GTA 5.7 THAT I PUT SLP SIAMISED RUNNERS ON..
Old Feb 20, 2010 | 10:52 PM
I WOULDN'T CHANGE THE MAF YET! SOUNDS LIKE ITS GIVING THE COMP A FALSE READING CAUSED BY THE VAC LEAK!!! HOW ABOUT THE O-RING ON THE NINTH INJECT MISSING? TRY SPRAYING LIKE WD-40 WITH THE TUBE STEM WHILE ITS RUNNING TO PIN POINT MORE WHERE ITS LEAKING FROM. THE WD OR EQUIVELENT WILL CHANGE THE RPM'S... GOOD LUCK, LARRY
Old Feb 21, 2010 | 12:00 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
The O ring is not missing but the metal flange looks a little out of shape. I am going to take it apart again tomorrow and see what I can find.
Old Feb 22, 2010 | 06:29 PM
quisterio's Avatar
Car: 87' GTA
Engine: 350 L98 TPI
Transmission: 700-R4
Axle/Gears: 3.27 9-Bolt
How bout the brake booster line at the back of the plenum?
Old Feb 23, 2010 | 10:17 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I fixed the leak. I had a newer style plenum on it and it was leaking from one of the egr holes in the runners that wasn't covered.
Grant2k
Jul 10, 2018 04:01 PM
lakeffect2
Aug 23, 2015 08:44 AM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
