distributor bushings?
Old Feb 18, 2010 | 12:24 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I've seen these listed in parts sections before, but never gave much thought to it, but now have my distributor apart, and don't remember seeing anything like these in there. Is there a chance that the originals are/were so far deteriorated that I didn't even notice them? Anyone know anything about them?
Old Feb 18, 2010 | 03:20 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: distributor bushings?
uhh, that's a new one on me? I can't recall where the bushing would go...? I've had mine apart, shimmed out the end play, etc, but I don't recall there being replacable bushings ?
Old Feb 18, 2010 | 03:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
They go on the post for the weight to pivot on. Not all weights use them.
Old Feb 18, 2010 | 11:07 PM
basiccamaro's Avatar
A GM HEI distributor has bronze shaft bushings. I have changed out bushings that showed wear on the opposite side from the cam gear thrust forces. I ground light diagonal oil grooves in the new bushings opposite the gear side of the shaft before installation for better lubrication of the bushings. I don't know if all dizzys are like this, but I would think so.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Damon
Sep 26, 2015 04:29 PM
