cylinder bore and piston matching
Old Feb 18, 2010 | 08:58 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
I have a 350 that has been bored 20 over stock. The engine was originally matched with 20 over pistons when machine work was done. But 4 yrs and 3 people later 2 of the pistons are missing. my question is , is it possible to buy new 20 over pistons and install them into my engine? would that be ok or would i need to go with bigger pistons and machine the block to match?
Old Feb 18, 2010 | 09:03 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: cylinder bore and piston matching
I think the cylinders need to be rehoned so the new rings can seat. Also, make sure the new pistons and wrist pins are the same weight as the other pistons, otherwise a rebalance may be needed.
Old Feb 18, 2010 | 09:11 PM
Engine: 350 for now
Transmission: wc t5
the block is 100% ready for rebuild. all machine work is done and it has new freeze plugs and is painted. would i have to rebalance if i went with 8 total new pistons and just kept the 6 thats left as wall ornaments?
Old Feb 18, 2010 | 09:38 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
You probably should do a rebalance either way, but you're good as long as all 8 pistons are within 1-2 grams of each other. If you get a new set, you should still be fine as long as each new piston is within 8-10 grams of the old one.
Old Feb 18, 2010 | 09:50 PM
Engine: 350 for now
Transmission: wc t5
ok. so how do I rebalance?
Old Feb 18, 2010 | 09:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Just get 2 more pistons of the same part number and weight match them to the rest.
Old Feb 18, 2010 | 10:20 PM
Engine: 350 for now
Transmission: wc t5
ok thanks for the knowledge Aperion and fast82.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
db057
Apr 28, 2019 07:45 AM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
