lb9 no spark problem
Old Feb 25, 2010 | 11:47 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
as title says my engine wont start because of no spark what are some reasons for this. I put a new ignition module but that isnt it. What are some other reason for no spark. It feels like its not turning over as fast as it did when it was running
Old Feb 25, 2010 | 07:09 PM
bcmag's Avatar
Re: lb9 no spark problem
bad pick up coil in dist could cause this.did you check to see if dist turns while cranking?bad timing chain,stripped dist gear?are you getting inj. pulse? if so disregard .
Old Feb 25, 2010 | 10:12 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
In what ways could i test the pick up coil. I've never seen it but its somewhere on the bottom of the distributor right. One thing i might add is that sometimes i am able to get it to turn on if i let it crank for a long time (about a minute) it starts with a sputter hear and there and then it will run for about 30 seconds. And a little more background, it died when i came to a stop light. it was the first time it had ever seen snow since i had it ( first time i had seen it in my life, im from austin) the battery turned out to be bad too but that is replaced now.
Old Feb 26, 2010 | 12:24 AM
spiffiestpengui's Avatar
Car: 1983 z28 and 3000gt twin turbo
Engine: 305 v8
Transmission: auto with b&m shifter
Axle/Gears: i dont know. they're stock
So you have checked to see your not getting spark for sure? mine was doing the same sort of thing, it was because i was getting flooded pretty bad, bad enough to where gas actually came out when i took the plugs out and they were soaked in it.
Old Feb 26, 2010 | 07:21 PM
bcmag's Avatar
first, are you certain you have injctor pulse and fuel pressure...just no spark?
db057
Sep 4, 2015 07:57 AM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
92camaroJoe
Aug 13, 2015 06:07 AM
