355 = NO POWER ??? WHAT IS GOING ON?
Old Feb 27, 2010 | 01:07 PM
jls172008's Avatar
OK, I HAVE A 90S MODEL GM CRATE MOTOR THAT HAS BEEN COMPLETLY REBUILT, HERE IS A LIST OF THE MODS
7QT OIL PAN
HIGH FLOW OIL PUMP
CRANK WAS TURNED
BORED .30 OVER
FLAT TOP PISTONS
COMP CAM 268
STOCK 993 CASTING HEADS
EDLEBROCK PERFORMER 2101 INTAKE
HOLLY 600 DP
HEADMAN HEADERS
HEI 65000 VT DIST.
8.8 WIRES
ACCEL PLUGS
MSD 6AL
FLEX A LITE DUAL COOLING FANS
DBL ROLLER TIMING SET
OK NOW THE PROBLEM. I HAVE BEEN TOLD THAT IT SHOULD BE MAKING AROUND 310 OR SO HP AND ABOUT 370 TQ. THERE IS NOW WAY THAT IT IS MAKING IT THOUGH. ME AND MY BUDDY RACED IT AND MY MOMS GRAND AM AND IT LOST!!! LOL BUT ANYWAYS THE CAR (85 TA) SEEMS TO LOOSE ALL POWER WHEN IT HITS SECOND GEAR. I HAVE BEEN TOLD THAT THE TIMING IS OFF SO I AM GOIN TO ADJUST IT BUT I REALLY DONT KNOW HOW IT SHOULD BE SET, ANY IDEAS? BUT MOST OF ALL IM TRYING TO FIGURE OUT WHY THIS CAR HAS NOT GOT THE POWER THAT IT SHOULD HAVE. ANY IDEAS ON WHAT IS GOING ON?
Old Feb 27, 2010 | 03:12 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: 355 = NO POWER ??? WHAT IS GOING ON?
The timing being off can do it, i lost a whole second in the 1/4 mile when mine was off by 10 degrees once.
I'll let someone familiar with your heads give you a number for advance though.
Old Feb 27, 2010 | 03:26 PM
jls172008's Avatar
what should the timing be set at?
Old Feb 28, 2010 | 12:49 PM
j_camaro_67's Avatar
Car: dark hunter red 84 camaro
Engine: 414 stroker
Transmission: th350
Axle/Gears: 3:70
for my 350 same set up, i think i ran base timing at 16 and advanced at 32 reving at around 2500. hope this helps.
Chuck84TA
Jul 15, 2016 09:05 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
sailtexas186548
Aug 24, 2015 10:11 PM
355tpipickup
Aug 13, 2015 07:35 AM
