getting no spark. please help
Old Mar 1, 2010 | 02:49 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I found that the coolant hose got to close to the altenator blade and it spewed coolant everywhere. The altenator was soaked but dont think any got near the distributor. I was about to time the car about 6 hours later. It started right up and i let it idle for about 2 minutes. I hooked the timing light up and checked the timing, it imediately shut off the second i pressed the timing light button. Now it will not start at ALL. it dosent even try. It just turns over.
I looked at the distributor as the engine was spinning and im not getting any spark. Battery is completely charged and everything is connected. What should i look for? I REALLY need some help guys.. please
Old Mar 1, 2010 | 07:41 PM
Engine: 383 Stroker
Transmission: t-56
Re: getting no spark. please help
it was the coil. thanks
MM2Robinson
Oct 1, 2017 09:16 AM
justin57
Aug 20, 2015 07:05 PM
transamgta1Khp
Aug 17, 2015 12:18 PM
Grumpy
16
Feb 11, 2002 05:20 PM
Bort62
Dec 10, 2001 06:01 PM
