misfire when hot
Old Mar 2, 2010 | 07:18 PM
campbellerman's Avatar
Car: 1990 Trans Am
Engine: 305 TPI L98 cam
Axle/Gears: 3.42 eaton
misfire when hot
ok i have been having this problem for a while now. the car runs fine but it misfires a little at idle.i have done a compression test and all the cylinders are up to specs. i have replaced the coil with a msd, new bosch wireset, new platinum plugs, accel cap and rotor, and set the base timing to spec, new injectors,cleaned iac and throttle body, new bosch o2, the car runs fine except for this little problem; i would like to fix this because it bugs me. what else should i test? the only thing that i haven't replaced is the ign. module but i had it checked 15 times at autozone and it passed every time. could this cause my problem? many thanks in advance
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Thaney9
Oct 24, 2015 07:26 PM
NZKnight
Oct 15, 2015 02:47 PM
mfp189
Sep 27, 2015 09:25 AM
ironbmt
Sep 27, 2015 06:00 AM
