engine studders and back fire
Old Mar 4, 2010 | 03:06 PM
89chevycamaroRS's Avatar
Car: 89 Camaro RS / 02 Silverado Z71
Engine: 1999 LS1
Transmission: 4L60e
Axle/Gears: 3.73 detroit truetrac
i have an 89RS 305 TBI. i just got it out today for the first time after the winter. i drove it about 12 miles with no problems then all of a sudden i hit the gas and it started studdereing like it was missfireing and it back fired alittle. i was able to get it where i was going but i had to be real easy on the the throttle.
i took the air cleaner off and when i hit the gas hard it back fired up through the throttle body with a little fire ball. if i slowley press the gas to higher RPMs it seems to be fine. but if i step on it it just jerks all around and wants to stall. i ilde seems ok but just alittle rough but not to bad.
i tried the sea foam thing because i thought it might be gas but it didnt seem to help
any suggestions would be great!
Old Mar 4, 2010 | 03:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Try changing the fuel filter. Make sure your ignition is up to snuff as well.
Old Mar 4, 2010 | 06:25 PM
Engine: 1999 LS1
Transmission: 4L60e
Re: engine studders and back fire
i just got done changing the fuel filter. seems to run good so far. i have not drove it yet to make sure but it reves fine now and seems to ile alot smother.
thanks for the input
Old Mar 17, 2010 | 08:51 PM
Engine: 1999 LS1
Transmission: 4L60e
well i drove that car a couple times with no problems (estimated about 50 miles). even got new gas in the tank. then today it started doing it again. i had to get it home by shifting it manualy because if it would shift into over drive or the next gear it would bog the engine abit then start backfireing and sputtering. if i used the gears manualy and slowly got on the gas i could get up to speed with no problem
could it be a fuel pump maybe? if so what is the fuel pressure supose to be?
my dad seems to think it might be a timing issue but i dont think it is because i can rev it high with no problem as long as i give it slow steady throttle but if i jump on it it back fires a studders.
idle seems alittle rough but not bad... it will stay running by ist selt
any help will be great thanks
Old May 24, 2010 | 09:05 PM
Engine: 1999 LS1
Transmission: 4L60e
i still have the same problem. i have looked all over the internet to see if anyone had the same problem. i found alot of cases of the same problem but all seem to end with out the problem fixed. i saw one did say and O2 sensor fixed his.
what should my reading be on a scanner so i know if it is that.
the car only has this problem after i drive the car for about 30 min.
Any help?
Old Jul 21, 2010 | 08:54 PM
Engine: 1999 LS1
Transmission: 4L60e
well i changed the coil and it seemed to fix it. no problems so far
Old Jul 21, 2010 | 09:12 PM
85projectZ28's Avatar
Car: 1985 Camaro Z28
Engine: 5.7 LSX
Transmission: Performabuilt 4L60E
Axle/Gears: Strange 12-bolt 3.73
hey man, i was having almost the exact same problem! i changed the fuel filter, the fuel pump, the spark plugs, the wires and the distributor cap. nothing fixed it. so i took it to a shop and he said it was the MAF sensor. he disconnected it and it ran almost perfect! but on any normally running car, if you disconnect the MAF it will run just a little bit worse than normal. but this solved the problem for me, because when it was connected, it was completely screwing up my idle and throttle because it was giving out or gone altogether!
so... if you have a MAF, try that!
Old Jul 23, 2010 | 02:53 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
TBI does not use a MAF. One thing I have seen a few times on TBI systems is a broken FPR spring. The FPR is built into the TB and can be disassembled and rebuilt. The spring is exposed to atmosphere with a poor seal to keep moisture and oxygen out. The ones I have found broken were rusted and had basically crumbled. The broken spring caused a severe loss of fuel pressure so that the engine would idle poorly and drivability was almost nil.
This can be checked by testing fuel pressure. FP should be about 9-13psi at idle. A quick visual check can be done by watching the spray pattern at idle. It should be a wide cone pattern and clearly hit the inside of the throttle bore and mist slightly on throttle snap.
Jae992
Aug 27, 2015 09:07 AM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
