vortec heads
Old Mar 5, 2010 | 06:55 PM
thebigstroke's Avatar
vortec heads
what do i need to do to get .552" of lift out of the vortec heads? ive got the matched spring and retainer kit from crane part # 10369-1 which can handle .550 of lift is there anything else i can do to get just a little bit more lift out of these heads? thanks in advance!!!!
Old Mar 5, 2010 | 09:15 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: vortec heads
+.100" longer valves, +0.050 keepers/locks?
Old Mar 7, 2010 | 10:21 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: vortec heads
if you are going for that much lift, you need to have the heads machined appropriately.
Do not push the limits. You really need to do some good measuring on things to make sure you have plenty of room and that you will not have coil bind, hit the seal, etc.
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
z28guy134
Sep 1, 2015 11:50 PM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
