87 5.0 T5 Center console/tranny Vibration Issue
Old Mar 7, 2010 | 04:36 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
I have a weird vibration going on,,When i increase speed to shift from 4th to 5th..The console/shifter vibrates..If i'm in 5th at 45MPH and up,,and if i take foot off the pedal..(Hills/Corners)There is a one and half second lap time before the throttle actually is backed all the way off.Before the idle is all the way down.In between that time the console/trans shifter vibrates bad.Same as if i just barely get back into the pedal to speed up.It does do it while im in the pedal at cruising,but when i'm off gas,it doesn't.Except as i mentioned in between that time frame..The only thing i've done is replace the u-joints..It's so annoying..Any ideas?? Thank You..
Old Mar 7, 2010 | 04:39 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: 87 5.0 T5 Center console/tranny Vibration Issue
Bad motor and/or tranny mounts will do that.
Old Mar 7, 2010 | 05:13 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
Like bad compression?? The motor seems fine,,but maybe not..I putting a 5.7 in it this spring,,but guess i will have to deal with it til then.When i do, i will check the tranny mounts..Thanks for the info.
Old Mar 7, 2010 | 06:25 PM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
..If i'm in 5th at 45MPH and up,,and if i take foot off the pedal..(Hills/Corners)There is a one and half second lap time before the throttle actually is backed all the way off.Before the idle is all the way down./quote]
The high speed idle solonoid is activated until the VSS senses speed below 35mph. It is iritating but I don't know of any way to bypass it without removing the computer completely. As for the vibration , I agree with the post above , check motor mounts, tranny mount and torque arm mount.
Old Mar 7, 2010 | 06:38 PM
seventy77's Avatar
Car: 87 GTA
Engine: 5.0
Transmission: 5spd
Axle/Gears: 3:45
K,thanks guys..
colton_carlson
Mar 8, 2019 12:21 PM
steimel94
Sep 23, 2015 12:48 AM
anesthes
Sep 21, 2015 10:24 AM
steimel94
Sep 20, 2015 12:46 PM
