Hypertech chip cause emissions failure?
Old Mar 8, 2010 | 11:13 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
I have another post going.
https://www.thirdgen.org/forums/tech...sions-nox.html
I failed to high on NOX, A buddy of mine asked if there was a chip in the, not sure if the prev owner put one in. So I pulled the comp and it has a hypertech chip in it. It's a street runner chip pt no 121321
It says the idle/part throttle isn't affected so emissions and fuel economy aren't changed. 49state legal though, so why not able to use in cali if it doesn't alter emissions?
I am assuming advanced timing from the chip would cause my nox issue? I have already pulled the chip and want to run it through again, just want some other thoughts/reassurance. This damn car with it's emissions crap is driving me insane.
Old Mar 9, 2010 | 10:43 AM
Re: Hypertech chip cause emissions failure?
I removed the chip and went through again. All things being the same except ambient temps (slightly cooler) Nox went from 2.81 with the chip to 2.59. So maybe it had a small effect. Definitely not the root cause of failure.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
Fanatic1074
Oct 2, 2015 03:47 PM
