will this cam work or not?
Old Mar 9, 2010 | 01:20 PM
shanep1991's Avatar
i have a 1989 chevy 350 im putting together with vortec heads, and flat top pistons and ill have roughly 10:1 CR but will this cam fit in my engine? if not can i do anything to make it fit?
http://www.summitracing.com/parts/SUM-K1107/
Old Mar 9, 2010 | 01:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: will this cam work or not?
It'll fit, but if your block is machined for it you could use a factory roller setup instead.
Old Mar 9, 2010 | 01:38 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Physically fit in the block -yes.
You still have to address the lift limit of the heads and whatever springs you intend to use. You'll also have to check for piston to valve contact.
The only way to know these things for sure is to measure what you've got with the parts you intend to use. There is no other way.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Jake_92RS
Jan 28, 2020 10:37 PM
camaro71633
Sep 1, 2015 10:24 AM
masonta
Aug 31, 2015 10:14 PM
Fronzizzle
Aug 9, 2015 01:15 PM
