Replacing starter help please!
Old Mar 10, 2010 | 06:34 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
hey my friend was trying to put in my new starter for me and had got all the wires undone and got the two mounting bolts off, but we cant get the starter pulled out cause everyway he turns it the solenoid gets caught on the brackets and the exaust is in the way. does anyone know where i can get some instructions?
Old Mar 10, 2010 | 07:35 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
Re: Replacing starter help please!
i read that there's a special way you have to twist it out, if so anyone have a video or pictures?
Old Mar 10, 2010 | 07:57 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
You might have to loosen or lower the y-pipe.
Old Mar 10, 2010 | 08:12 PM
ksith's Avatar
Car: 87 trans am
Engine: 5.7
Transmission: t-5
Axle/Gears: 9 bolt posi 3:27
you will definatly have to at least lower the y pipe that starter isnt coming out unless you do.
Old Mar 10, 2010 | 08:41 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
alright thanks guys
Old Mar 10, 2010 | 10:22 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
I didn't loosen the y pipe. I just twisted and turned till it came out. Don't remember exactly which way I did. But you can fight it out.
Old Mar 10, 2010 | 11:04 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
well pretty sure i read somewhere u tip the front end down and twist and pull it will come right out.... will try tomorrow again lol
Old Mar 10, 2010 | 11:06 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
The problem is depending on how close your exact system is together you may be able to get the starter out by twisting it, but trust me it will be just as much of a pain if not more of a pain to put it back on. Personally i would just lower the y pipe its four bolts.
Old Mar 10, 2010 | 11:07 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
I did mine and there was no way for it to come out without removing the solenoid first.
Old Mar 10, 2010 | 11:15 PM
Kguffey84's Avatar
Car: 92 RS
Engine: 5.7 SB
what about putting new one in??
Old Mar 11, 2010 | 04:48 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
An option is to use the LT1 starter. It is smaller in diameter and lighter, too. It doesn't help you getting the old one out, but as mentioned earlier, you can try taking the solenoid off.
Old Mar 11, 2010 | 05:38 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Yeah def go with an LT1 starter. They're like $170 with a core, $200 new... but I got a junkyard LT1 starter off ebay for $30 and it's kickin just fine. If it breaks I can just go turn it in and not lose any money on it. Try to do something like that if you can wait. It's so much nicer to handle and cuts a good bit of weight.
Old Mar 11, 2010 | 01:10 PM
MetallicaWolfe's Avatar
Car: 1986 Berlinetta Camaro
Engine: 350 SWAP
Axle/Gears: Stock
yup been there done that alot....exhaust has got to come down some unfortunately
Old Mar 11, 2010 | 02:01 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
That is exactly what I did. $20 from the JY. Grab the bolts, too. One is long and one is short.
Old Mar 11, 2010 | 04:18 PM
89_ho_rs's Avatar
Car: 1989 RS Camaro
Engine: 350 Carb(soon a 400)
Transmission: 5-Speed/th350
Axle/Gears: 10 bolt 3.73
i got a tilton mini starter lots of room. got mine for 40 bux. but with my old starter when i had manifolds on it it was a pain but i remmeber i was able to get it out and in without droping the y pipe but it prob would have been easier if i had droped it.
Old May 24, 2010 | 07:40 PM
ogg__666's Avatar
Car: 1988 iroc-z28
Engine: 305 tbi
Transmission: new 700r4
Axle/Gears: um 2.77 i think
LMFAO you guys are all lucky my starter exploded so it came out easy but they wouldnt give me my core charge for it !!
mhatfield 14
Oct 24, 2015 07:48 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
milk
Aug 10, 2015 06:26 PM
86Base
Aug 8, 2015 01:34 PM
