Misfire?
Old Mar 12, 2010 | 06:48 PM
ProjectBird85's Avatar
Car: 1985 Trans Am
Engine: Procharged Small block 355
Transmission: TH-350 modified
Axle/Gears: Richmond 410
Misfire?
Just got word from the shop that they can't install my MSD because the engine has a misfire. When I got my car all the spark plugs were loose and the wires off (previous owner did a compression test) I was able to get them tight with the exception of a couple that I could only hand tight. I replaced the cap/rotor that has the HEI. I thought the car ran great. Anyone know what might cause the misfire in only 1 cylinder?
Old Mar 12, 2010 | 06:59 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Misfire?
Plug still loose. Wire loose. Corrosion. Fouled plug. Failing injector. Loose connection on injector. Low fuel pressure... maybe.
In any event, none of this should matter as far as the MSD box is concerned. They should be able to install it anyway. Not sure where that reasoning came from. (unless, they want the miss fixed first, so if it runs funny when they are done, they know they started with a good running car.)
Old Mar 12, 2010 | 07:06 PM
Car: 1985 Trans Am
Re: Misfire?
Doesnt have Fuel injection it's carbed. They didnt want to install the MSD because they want to get it dyno tuned. Thats what Im leading to, either that or the firing order is off. Not sure, I hope it's nothing internal. Also before I got the car it sat for about 4 years so Im not sure if the plugs and wires are bad.
Old Mar 12, 2010 | 07:12 PM
ploegi's Avatar
Engine: 5.7 TPI
Re: Misfire?
Erm, what does the MSD have to do with being dyno tuned? I would think they would WANT it on there for that exercise???? No??
If the firing order was off, you would have misfire on two cylinders. In your first post, you stated that at least one of the plugs was only hand tight, start the engine, and run it, and the plug WILL back out. That might be the whole problem right there....
A vacuum leak where the intake manifold hits the head, if is leaks into a runner, would also cause a misfire on one cylinder.
Old Mar 12, 2010 | 07:24 PM
Car: 1985 Trans Am
Re: Misfire?
Im not sure why they didnt install the ignition first. Yeah they told me only 1 cyl was misfiring. They are going to check it Im hoping tomorrow. The shop has had it for 2 day's and this is as far as they've gotten. Very frustrating.
db057
Jan 10, 2020 08:55 PM
NZKnight
Oct 15, 2015 02:47 PM
camarohelp
Sep 22, 2015 03:19 PM
Jk_Under
Sep 8, 2015 08:13 AM
Thaney9
Aug 29, 2015 03:16 PM
