Found a 383 Need Your Opinion!!!
Old Mar 12, 2010 | 10:50 PM
FoodStampsz's Avatar
Car: 86 F-bird TA
Engine: 383
Axle/Gears: 4.10
Hey guys looking to upgrade my motor. Got a great deal on this block out of a camaro and just wanted to see what you guys think of it and what a good price might be. Any info is good info please post!
.010 block that went through all the good machining procedures.
Dart iron eagle 200cc/72cc 2.02 heads
comp xe284 nitrous cam with new double roller timing chain set with new lifters
sce ics titan head gaskets, copper self sealing no oring the block very high end srp 140344 forged dome pistons
scat 4340 forged 5.7 i beam rods bushed with arp bolts
New eagle 383 cast crank
Edelbrock torker single plane intake
moroso tall valve covers
1.6 roller rockers
New hardened pushrods
Holley 750cfm 4 barrel carb rebuilt with blue gaskets and some extras choke horn taken off vacumm secondaries
7qt stroker clearenced oil pan with scraper and trap
new powerforce 8" stroker balancer
chrome timing cover
altonator with the alan grove alt mount
new proform waterpump
1inch spacer with flex fan
newer stock power steering pump
newer ac delco hei distributor
ministarter
quick ratio steering box
Old Mar 12, 2010 | 11:23 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Found a 383 Need Your Opinion!!!
How many miles on it? Could you hear it run or is it a take home & assemble?
Old Mar 13, 2010 | 07:27 AM
Car: 86 F-bird TA
Engine: 383
Axle/Gears: 4.10
Probably should have mentioned that, No miles on it just broken in, running for about an hour with break in oil. Needs a carb, has a vacuum leak and a carb thats been rebuilt like 3 times. Comes along in a car (so I can hear it run as well)that I will be using for the motor and wheels then swapping my motor and gifting to the wifey.
Thanks!
gixxer92
Sep 1, 2015 04:32 PM
Thornburg
Aug 25, 2015 01:46 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
