Tach nightmare.
Old Mar 12, 2010 | 01:11 PM
dfitch's Avatar
Car: 92 RS, 01 huyndai, 96 acura, ect...
Engine: 305 tbi
Tach nightmare.
I swapped the whole cluster and each time the tach just rolls all the way up and pegs. I think it's the IC chip on the right side of the cluster. Does anyone know what I need to do to fix the problem?
Old Mar 12, 2010 | 01:14 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: Tach nightmare.
i think its a connection problem. sorry i don't know exactly but mine does it only when i turn my headlights on.
Old Mar 12, 2010 | 01:18 PM
dfitch's Avatar
Engine: 305 tbi
Re: Tach nightmare.
I think you have a crossed wire in that mess behind the dash. mine does it as soon as i reconnect the wire from the coil and start the car. I think we're dealing with two different issues but I'm really not sure. I'll let ya know if I find anything out.
Old Mar 12, 2010 | 04:25 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Tach nightmare.
https://www.thirdgen.org/forums/elec...meter-fix.html
Old Mar 13, 2010 | 12:56 AM
dfitch's Avatar
Engine: 305 tbi
Re: Tach nightmare.
I've read through the article. The problem is this using a variable resistor, is this it will be extremely difficult to tune to the correct ohm rating. I'd rather just buy a working chip but I can't find one anywhere. Any leads?
By the way MotorMouth, Nice ride looks just like mine aside from the rims.
Old Mar 13, 2010 | 05:10 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Re: Tach nightmare.
All you have to do is to unsolder the connections for the 2 pins and get it to 198k ohms or as close as possible. That is the way mine was done and it worked out great. If you know someone who works in maintenance maybe they can for it for free. That's how I got mine fixed. We looked and the closest we could get it was using the 5 in this pick.
Thanks for the complement. Too bad she doesn't look that good now. But come next year she will be better than ever!
Old Mar 13, 2010 | 11:44 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Re: Tach nightmare.
I have a repaired IC board tested and working i will sell , pm me if interested
$750 L98
Feb 1, 2025 02:25 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
327IROC85
Sep 23, 2015 12:11 AM
TrevinE
Sep 14, 2015 03:20 PM
