vaccuum advance question
Old Mar 12, 2010 | 11:13 PM
davep_96's Avatar
Car: 1987 Trans Am GTA
Engine: 355
Transmission: TH-700r4
My engine has a standard aftermarket HEI with a Vaccuum advance. After my build was complete I set the idle timing at around 8-10 degrees and I never hooked up the vac adv to the carb. This was because as I recall the timing advanced by just the springs to an acceptable amount(Im sorry I dont remember the rpm or the degrees. My uncle helped me and it was last summer) My question is do I need to hook up the vac adv? What are the advantages or disadvantages of using it? Also what should final timing read and at what rpm for a 355? Sorry for the newbie questions
Old Mar 13, 2010 | 12:48 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: vaccuum advance question
Vacuum advance will improve part-throttle response and cruise mileage, and reduce plug fouling.
pfsteichen
Feb 9, 2016 06:59 PM
lt1z350
Aug 28, 2015 05:57 AM
Bert87
Aug 23, 2015 03:50 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 11, 2015 10:22 AM
