which water pump
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: which water pump
the length of the output... this should help
[long] http://www.summitracing.com/parts/EDL-8811/?rtype=10
[short] http://www.summitracing.com/parts/BRA-1688/?rtype=10
easiest way, if there's only a tiny bit of room between the back of the pump & the timing cover, it's short. If you can get your finger in there, it's a long pump.
Most cars use long pumps. Not many use short pumps (corvettes are one)
evilstuie
Jan 9, 2020 08:29 PM
Dialed_In
Aug 20, 2015 01:45 PM
