removing serpentine belt tensioner?
Old Mar 13, 2010 | 05:38 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
How do you remove the serpentine belt tensioner on a 1991 V8 car? I see a large torx bolt in the center of it that would probably remove it, I'm just afraid that the spring inside might pop out and make re-installation a bear. Thanks!
Old Mar 13, 2010 | 11:08 PM
Engine: LB9
Re: removing serpentine belt tensioner?
... a picture is worth 1000 words:
Old Mar 14, 2010 | 07:19 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
That's the bolt.
No worries about the spring. It won't pop out.
Old Mar 14, 2010 | 12:11 PM
Engine: LB9
Originally Posted by Viprklr
That's the bolt.
Thanks!
Old Mar 14, 2010 | 06:51 PM
sdirocker's Avatar
Car: '88 IROC-Z
Engine: 305ci TPI
Can the pieces be seperated for painting (with spring removed) or that asking for trouble?
Old Mar 14, 2010 | 07:12 PM
Engine: LB9
I just took the tensioner off today and there's some interesting looking clips or pressure fittings... not something I'd wanna mess with. And that spring probably has a lot of force behind it considering how it presses down on the belt. I'm actually bringing my engine brackets in for blasting/powder-coating tomorrow. I'll see if they can at least sandblast the tensioner so I can paint it myself if anything.
Old Mar 14, 2010 | 09:18 PM
sdirocker's Avatar
Car: '88 IROC-Z
Engine: 305ci TPI
Decided not to risk taking it apart. Just masked (the black retaining plate) and painted it. I cleaned it up with solvent and steal wool first and it looked pretty good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
buckshot63
Interior Parts Wanted
Sep 3, 2015 08:10 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
