What is really needed under my hood...
Old Mar 13, 2010 | 09:53 PM
Weffy's Avatar
Car: (sold 85' IROC Z28)
Engine: (89' 305 TPI)
Transmission: Looking for a classic chevy
Since I currently have the engine out of my 85 TPI, I want to take the chance to clean it out. Not just clean it, but get rid of everything that my car doesn't need to drive.
All the a/c is already gone.
Same with A.I.R.
Is the EGR valve on the intake needed? Can I plug it?
I'm also trying to keep the wires to a bare minimum. I'm not 100% sure on what sensors absolutely need to be hooked up but this is what I can think of.
-knock
-O2
-MAF
-Oil pressure
-Coolant temp
And now I'm drawing a blank. I'm trying to plan this all out on how the bay will look when its done. Maybe someone can tell me what circuits are needed. I have the haynes here and all the schematics.
Old Mar 13, 2010 | 10:10 PM
Damon's Avatar
Re: What is really needed under my hood...
You've already removed most of the stuff you can. Only other hoses you can take off are for the charcoal canister (evaportative emissions system).
EGR system is necessary. The ECM has a temp sensor in the EGR system that it references to see if the valve is actually opening when it commands it to open (applies to any MAF-equipped TPI engine year). The only "right" way to defeat the EGR system is to turn it off in the chip programming. If you do that THEN you can remove the physical parts from under the hood.
Old Mar 13, 2010 | 10:14 PM
Weffy's Avatar
Okay, well then what does the charcoal canister and hoses look like?
Is the canister in the fender?
Old Mar 13, 2010 | 10:32 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Yes. See the thread by Rocco titled Why is this disconnected
There are some photos & a lil explanation what the canister is for.
Old Mar 14, 2010 | 03:50 AM
Weffy's Avatar
Okay cool, now I found the vacuum line diagram for my 85 tpi, its attached.
Where should I plug this to remove the canister and as many lines as possible?
I'm thinking plug the line from the fuel tank, and then if I left the EGR solenoid there should I plug the end thats supposed to go to the canister, or should I leave it open, OR do I even need the solenoid.
Sorry if this is redundant/ or has been asked a million times, I just can't seem to figure this out.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Zachattack0925
Aug 12, 2015 09:52 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
