Compression Ratio Estimate
Old Mar 15, 2010 | 08:40 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I am going to be building a 383 shortly and am wondering around what my compression ratio will be. It will be a 383 (4.030 bore 3.75 stroke) with 65cc cylinder heads, +5cc pistons, and probably a .035 head gasket. I have tried calculating it but usually get different estimates, most of them being around 10.7:1. Does this sound correct? And I will be using a summit 383 block, so I believe the block has a stock deck height.
Old Mar 15, 2010 | 09:08 AM
Damon's Avatar
Re: Compression Ratio Estimate
You're talking about flattops with 5cc worth of valve reliefs? If so, then yes, you'll be somewhere in the mid 10s.
I ran your combo with the pistons sitting .025" in the hole at TDC plus a FelPro .039" head gasket (~9cc) and got 10.31:1. Same same but using a .028" GMPP head gasket and it's 10.65:1.
Old Mar 15, 2010 | 09:20 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Yeah I meant 5cc worth of valve reliefs. Thanks
InfernalVortex
Apr 20, 2021 11:31 AM
FormulasOnly
Jul 23, 2018 08:47 AM
Vincent135
Sep 28, 2015 10:50 PM
Damon
Sep 26, 2015 04:29 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
