Spark plugs
Car: 86 Iroc
Axle/Gears: GU5 323
Spark plugs
My 86 Iroc hasn"t had new plugs in over 6 years ( From the owner before me ) I'm a little nervous on just slapping a rachet on them since they look extrememly rusty. Any " tricks of the trade " to getting them out w/o snapping them??? Thank you
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: Spark plugs
wd40 or penetrating oil, let them soak. the worst that could happen is you knock the porcelain off or round off the hex part but that's not likely with the right socket.
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: Spark plugs
well if you have stock manifolds, then follow the advice from the previous post... if you have headers, perhaps use a small ratchet with an adapter for the spark plug socket... oh and if you have headers, the passenger side is easier from the bottom, also note that if you do change the spark plugs on the passenger side from the bottom, it is a good idea to disconnect the negative battery terminal...
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Spark plugs
As mentioned above, use some sort of penetrating oil on them and let it sit overnight. Personally I'm a huge fan of PB Blaster ...the stuff works wonders.
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Re: Spark plugs
Tighten them just a little. Cracks em loose believe it or not. But I mean very little, just enough to feel it. Then turn them out. Put some anti seize paste on the new ones.
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
