Spark plugs for high CR
Old Mar 15, 2010 | 11:41 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
my setup is 383 with 165cc heads (combusion chamber 64cc) and flat top pistons with valve reliefs so that sends me to high CR. intake is HSR, cam CS XR276HR-12. as i,m not able to change these cylinder heads now i need to get proper plugs, which spark plugs should i choose ?? any part numbers whould be very helpful.
best regards
Old Mar 15, 2010 | 04:32 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: Spark plugs for high CR
Without knowing the exact heads it's impossible to give you a specific part number but I imagine a plug like Autolite 24's would be a good starting point.
Old Mar 15, 2010 | 06:23 PM
WASyL's Avatar
heads are Edelbrock 60859 http://www.summitracing.com/parts/EDL-60859/
Autolite is hard to get in Europe, can i use NGK BPR6FS (2623) or Champion RV12YC instead of AR24?
best regards
Old Mar 16, 2010 | 10:00 AM
WASyL's Avatar
bump as i'm still not sure
best regards
Old Mar 16, 2010 | 02:17 PM
EvilCartman's Avatar
Car: '82 Z28
Use the NGK plugs.
Old Mar 16, 2010 | 03:21 PM
WASyL's Avatar
thanks
best regards
evilstuie
Feb 28, 2016 03:33 PM
LittleFranks
Sep 17, 2015 12:22 PM
tricky1
Aug 23, 2015 01:17 PM
g.l.mos
Aug 22, 2015 12:02 AM
