Ticking noise from under plenum
Old Mar 16, 2010 | 12:15 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
I have a 305TPI in my 87TA. I Recently replaced my alternator, belts, plugs and wires along with the TPS and IAC and correctly reset everything. Problem is i have a ticking noise that i can hear in the car while driving. I have done everything to trouble shoot the valves, exhaust leak and injectors. My injectors to tick, but this ticking is different, and not as loud as the noise im hearing. I unplugged one injector at a time and the noise never went away. I dont have any exhaust leaks either, and my valves are not making any unusual sounds that i can hear when i put a screwdriver to the covers. The ticking seems to be coming from under the plenum. My question is, how would i check the stuff under there. If it was a EGR wouldnt i be throwing a code? I read in my searches that the FPR can make a ticking noise, but that was only in one thread so im not too sure there. What should i check next because this sound is quite annoying. It seems to stay pretty steady as RPMs rise also, it just ticks away.
Chris
Old Mar 16, 2010 | 05:17 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: Ticking noise from under plenum
Lifters maybe?
**How many miles are on the car?
Old Mar 17, 2010 | 12:29 PM
Saber's Avatar
I checked my lifters, they are not the source of this ticking. I used a long screwdriver and placed them on my valve covers every inch and the ticking sound is not coming from there, its coming from directly under the plenum, only problem is i dont know how to check what it is, i cant exactly take my plenum off and start my car..
Old Mar 17, 2010 | 12:48 PM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
How frequent is the sound? If it is a lifter noise it would be ticking at about half the engine speed.
Old Mar 17, 2010 | 07:39 PM
Saber's Avatar
It's ticking like an exhaust leak, sound wise and its quite frequent. Kinda sounds like a machine gun now. its a lot louder. It's directly under the plenum from what I can tell. In the egr, fpr, and dizzy area. It clicks at the speed of the engine, not half so valves are out. And I doubt its injectors.
Old Mar 17, 2010 | 08:21 PM
Saculia's Avatar
Engine: 305TPI
Can you get under the car and listen at the oil pan? Could be a rod bearing. Have you seen a change in oil pressure?
Old Mar 17, 2010 | 08:54 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
What injectors are you running?
Old Mar 18, 2010 | 12:21 PM
Saber's Avatar
I have stock Injectors. Also my. Oil pressure is reading normal and steady and doesn't fluctuate much. I have access to a lift so I can get under the car. What and how would I check underneath?
Old Apr 28, 2010 | 08:14 PM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
did you find your noise it sounds like the same noise i have after rebuilding my engine?
Old Nov 2, 2010 | 11:42 AM
Black'92's Avatar
Car: 1992 Trans Am Convertible
Transmission: 5 Speed manual
Did you get this sorted out? I am having the same problem!
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
