Coolant diverter work with carb?
Old Mar 19, 2010 | 10:51 AM
1988GTA500HP's Avatar
Car: 1988 GTA
Engine: 400 CI
I originally posted this in Cooling but haven't gotten any response. Maybe my fellow swappers could help me out.
Does this valve work with a carb? I was at the JY yesterday and saw one so I grabbed it. I was wondering if the feed from the plenum could be replaced by the feed from the intake manifold. I didn't know if there is a pressure difference. My vacuum lines were just cut at the firewall. Also if so, how do you know which vacuum line should go to the diverter valve? And the vacuum line to engine vacuum, where should that be tied in? Any help would be appreciated as I'm putting in a new heater core this weekend and need to plumb everything. The heat was eliminated on the car when I bought it.
Old Mar 19, 2010 | 01:20 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Why wouldn't it?
Sorry, can't help you identify which vacuum line is which. Mine don't even have the valve.
Old Mar 19, 2010 | 02:17 PM
Car: 1988 GTA
Engine: 400 CI
Re: Coolant diverter work with carb?
I didn't know if there was a pressure difference. It's only plastic. I couldn't think of a better way to keep hot coolant out of the cockpit during Florida's hot summers, so I'm putting it back in.
Thanks for the help.
Old Apr 22, 2010 | 06:25 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
there will be 2 vacuum lines 1 is for the vent doors once you hook that one up when you move it to a/c the other line will be sucking vacuum for the hotwater shuttoff
midge54
Dec 27, 2019 04:14 PM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
stalkier
Aug 13, 2015 12:59 PM
