what is that rubber/plastic dust cover boot on the steering shaft in the engine bay?
Old Mar 21, 2010 | 05:27 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
what is that rubber/plastic dust cover boot thing on the steering shaft in the engine bay?
its after the bolt that connects the interior columb to the steering shaft in the engine bay.
its right between the the mainifold and the brake booster on the steering shaft.
and what happens when its cracked? does it need tio be replaced immediately and how much would that cost?
Old Mar 21, 2010 | 05:45 PM
Gregzz4's Avatar
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: what is that rubber/plastic dust cover boot on the steering shaft in the engine b
Unless I'm wrong, the boot is a dust cover
Replace it when you can but it's not holding grease or anything so you can get by without it for now
Old Mar 21, 2010 | 05:59 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks a bunch. its still there and wrapped around not going anywhere. just has a crack in it now.
i was told if i wana replace it i gota replace it with the whole shaft.
no thanks.
ill have my mechanic take a quick look but no way.
Old Mar 21, 2010 | 06:03 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Not a big deal. You don't have to replace the shaft but you do have to remove it in order to replace the plastic piece.
JamesC
Old Mar 21, 2010 | 06:07 PM
Bobby_80s's Avatar
Axle/Gears: no idea
ok thanks james.
i mean i dont know if this is a common thing. i was jsut lowerign the columb inside to get to the starter connectors.
i asked around and didnt get any warnings about that dust cover.
Old Mar 21, 2010 | 06:09 PM
JamesC's Avatar
Odd, I've lowered my column several times without incident. At any rate, a crack shouldn't be a problem.
JamesC
Old Mar 21, 2010 | 06:12 PM
Bobby_80s's Avatar
Axle/Gears: no idea
thanks again james. im trying to get the car ready for the road now that winter is over and i was worried i was lookin at an expensive setback.
but my worries are put to rest. this site rules. haha
1992 Trans Am
May 10, 2023 07:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
