water temp gauge
Old Mar 21, 2010 | 09:29 PM
ricci66's Avatar
water temp gauge
i have an 1988 iroc ,......anyone HAVE or ever figure out WHY? the temp gauge jumps up to the high reading when cranking the engine over .....then back to .....way below the scale when started ....and stays there ....is it the gauge or the temp probe ...or the wiring ? seen this on a couple of other camaros in the past THANKS
Old Mar 22, 2010 | 06:52 AM
ricci66's Avatar
Re: water temp gauge
........ bump
Old Mar 23, 2010 | 12:52 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Temp Gage Is Nervous
It jumps to high as a self test when starting the car.
If you’re saying it never moves above cold when you’re driving awhile, the sender, or wiring to it, is bad.
Happy Racing!
“Push On Bumper To Spin”
Old Mar 23, 2010 | 01:06 PM
racethesunlive's Avatar
Car: '92 Camaro
You can test your wiring by grounding the temp sensor wire against the engine block. If the gauge pegs at over 260 degrees then your wiring is fine and its a sensor issue. If, while grounded, the gauge still doesn't want to move... its a wiring issue.
Old Mar 23, 2010 | 03:48 PM
ricci66's Avatar
THANKYOU ....for your input
Bubbajones_ya
Jul 6, 2024 08:32 PM
tommy z-28
Oct 6, 2015 10:58 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
86IROC112
Sep 11, 2015 04:04 PM
