Mild Cam in 305???
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Mild Cam in 305???
I am just wondering, but could it even be possible for me to put in a mild cam into my 1992 Firebird? THANKS!
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: Mild Cam in 305???
comp xe-268 would be fine, and you would have a nice "chop" with good street manners.
i had an xe-274 in mine, power brake vacuum was a bit low but at 650 rpm it sounded glorious! power band was 3k to as high as you dared to push it
Eric B
Eric B
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
You don't want to go with a huge cam like the xe268. Your 305 TBI heads and intake will not be adequate for something this big. Stick with something that makes power and torque between 1000 and 5000 rpm. The LT1 or an L98 cam would be a good, cheep alternatives that will make a difference compared to the stock cam.
If you want to go a bit bigger you can consider the comp xr258hr12. It is a good upgrade for the TBI engines, but will need to make sure the heads will accommodate that much lift. I recommend you install new valve springs with the new cam.
Engine: 305 TBI
Ok thanks for the input guys. i just want to know what kind are out there (already mentioned) and how compatible they are with my car..THANKS again!
Engine: 305 TBI
