Gazoline smell in water canister!!
Car: camaro iroc-z
Engine: 355 L98 Corvette engine
Axle/Gears: 3.27 9 bolt borg warner
hello
i test my engine today after the tpi to carb swap
and i smell gazoline in the coolwater !! yes i`m sure !!!!
what could this problem be ?
is there a leak between the intake gasket?
the engine is running bad to at rpm!
dennis
dennis
Car: camaro iroc-z
Re: Gazoline smell in water canister!!
are you sure ?
here in the netherlands some people said : broken head gasket or the head self or the engine is broken somewhere.
the engine is 3500 km old after compleet rebuild.
before it was a tpi and never had a fuel in coolwater problem.
dennis
dennis
Car: 87 Camaro
Complete rebuild = gaskets didn't seal correctly or your heads are cracked or warped. I'd still lean toward the gaskets.
