Trying to set timing....
Old Mar 23, 2010 | 03:23 PM
L695speed's Avatar
Car: '88 Trans Am GTA; '84 Trans Am
Engine: L98 350TPI; 5.3 LSx built
Transmission: N/A; T56
Axle/Gears: 3.70 9 bolt; 3.73 10 bolt
I'm starting over with my timing as its possible its out of wack. The problem I'm having is when I disconnect the 4 pin connector the car stumbles then stalls. I've read that the car should at least run abliet like crap when you do this. I want to ensure my base timing is dead on at 6 degrees, before I start taking apart the carb. Is it possible that the timing is out to the point where it won't run without the 4 pin connector attached? I have the dizzy marked so I can mess with it. I am going to be moving the dizzy lil by lil once I've established whether the timing is too far retarded or advanced.
82tabird
Dec 21, 2015 10:22 PM
lt1z350
Sep 29, 2015 01:50 PM
hydrolic144
Aug 29, 2015 04:14 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Aug 24, 2015 06:52 AM
mustangdmurder
Aug 21, 2015 07:17 PM
