Oil Pressure Gauge stuck at 0
Car: 1986 Trans Am
Engine: Vortec V8 5.0L
Hey boys.. my oil pressure gauge always reads zero.. has had this problem for a while? Don't know where to find the connector.. I assume once I know where it is, I can check the voltage to see if it's getting power, and then I know what to replace? The oil pressure sending unit or..?
Thanks for any help
Thanks for any help
Transmission: 4L80E/4L80E
"Vortec V8 5.0L"?
The oil pressure sender should be behind the intake manifold next to the distributor on the driver side.
ambainb
Apr 25, 2016 09:21 PM
