anyone using this style alternator bracket
Old Mar 25, 2010 | 06:53 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
i can't get leverage to tighten the belt. just curious if anyone else is having this problem and how you fixed it.
Attached Thumbnails anyone using this style alternator bracket-alt-bracket.jpg
Old Mar 25, 2010 | 06:55 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: anyone using this style alternator bracket
I don't see the adjusting slot. That sucker is fixed so you'll need to use a tensioner with it.
Old Mar 25, 2010 | 07:00 PM
its at the bottom. its bolted on the engine otherwise i would have a better shot.
Old Mar 25, 2010 | 07:28 PM
Damon's Avatar
Is that a mid-mount or low-mount? I always get to them from below (becuase the slider is on the bottom side, like you said). Just a short pry bar jammed between the alternator body and whatever is handy on the water pump or mounting tabs has always gotten it done for me.
Old Mar 25, 2010 | 08:39 PM
i guess i'd call it a mid mount. i'll pull it up on the ramps and try it from the bottom. this is a really cool bracket with this exception.
Hotrodboba400
Dec 10, 2019 07:07 PM
///DAN///
Brakes
Sep 17, 2015 07:43 PM
Hello, Michael
Sep 11, 2015 01:10 PM
1Aauto
Sponsored Vendors
Sep 8, 2015 11:14 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
