holley stealth ram swap
Old Mar 28, 2010 | 01:31 PM
rdsxfn524's Avatar
I need some help Ive got right now a carb but I want a holley stealth ram. What all do i need to do the swap, just the wiring harness, ecm, and sensors and then the holley intake manifold and all that? On that note what ecm should i get, Ive heard a eprom.
Old Apr 4, 2010 | 04:37 PM
shankymank78's Avatar
Car: 1991 1LE 350
Engine: 383 12.1 comp afr 195, hsr,
Transmission: 700r4 by probuilt automatics
Axle/Gears: 1o bolt 3.55 motive gears
Re: holley stealth ram swap
the holley stealth ram is a nice piece but be worned it takes alot of aftermarket parts to get it to work on a camaro. i have one on mine and im still finding out that i need more parts in order to use it. parts needed, fuel rail, fuels lines, small distributer, upgraded computer, coolant lines and fittings the list keeps going. i've spent well over two thousand dollars so far on this setup and still haven't got to the point were i can fire it up. i hope it lives up to it reputation.
Old Apr 9, 2010 | 11:26 PM
rdicarlo's Avatar
Car: 1986 Camaro
Engine: 72 350 4Bolt Main from a C20
Transmission: 700R4 B&M Shift Kit tci converter
Axle/Gears: Borg Warner 9 bolt 3:42
I have a complete Holley Stealth Ram MPFI kit for sale with a commander 950 computer.
here's the link... https://www.thirdgen.org/forums/engi...injection.html
Thanks,
Rob
Old Apr 10, 2011 | 11:26 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
I actually just installed mine after the motor build I have done and its not hard, but do need many parts to change.
New fuel lines/rails with adapters
New coolant hose
New thermostat neck
Plugs for the back for brake booster and other parts
List does go on and do need to modify other cables/parts to fit it. After that tho had no problem running tho. I cant tell power increase because my car wont idle since my other upgrades ive done. If need anything let me kno
Old Apr 12, 2011 | 08:01 AM
tslsa28's Avatar
Car: 91 RS and Jaguar XJS
Engine: ZZ383 with Mini Ram
Transmission: Tremec 3550
Axle/Gears: 3.42 with Tru Trac
Does the Stealth Ram fit under the stock hood? Can you still use a strut tower brace?
Old Apr 18, 2011 | 12:30 PM
Transmission: 700r
Yea you do have to modify the hood a little but yes it fits
No strut tower tho
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
L98GTA87
Aug 11, 2015 06:55 PM
