black smoke
Old Mar 28, 2010 | 01:38 PM
redfox's Avatar
Car: 91 rs, 97 firebird
Engine: 3.1, 5.7
Transmission: both 700r
black smoke
i have a 91 rs with a 3.1 . i had a oil leak and when we changed trannies we found it was a seal on the back side of the cam? thats the olny thing we could think of what it was. never seen a seal back there. but we fix it. now it flooded and foulded every plug, so i put bosch 2 in them. a week latter there all foulded out so i just put shorty plugs in it. when i give some gas it has black smoke coming out, and when it idels. we thought that it wasnt getting enough gas so we hooked it up and its getting 45 psi. i have no idea why it keeps fouling plugs out.
Old Mar 28, 2010 | 01:58 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
ok so i just pull the 2, 4, and 6 plug and the tips are all black. does any one have any idea that might lead me in the right direction. were thinkin it might be a o2 sensor
Old Mar 28, 2010 | 02:16 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
ok i now have all plugs and wires off. And there all have back tips. gonna jack the car up and check out the 02 sensor
Old Mar 28, 2010 | 02:27 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Re: black smoke
Black smoke usually means you are running super rich. Any codes?
Old Mar 28, 2010 | 02:30 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
no codes yet
Old Mar 28, 2010 | 02:38 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
ok 02 sensor is out. all the fins are pluged. and we have heard that sometimes you can clean them up and they will work.has any one else heard this
Old Mar 28, 2010 | 03:26 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
ok, so i took the o2 sensor off, cleaned it on a wire wheel and blew it out with low air pressure. cleand up the plugs and checked my wires over. put them all back on. fired it up a little bit of white smoke but it dont smell like its runnin rich. backed it out of the shop and its still running fine.
Old Mar 29, 2010 | 08:08 PM
redfox's Avatar
Engine: 3.1, 5.7
Re: black smoke
i guess you can clean a o2 sensor. problem fixed, case closed
gta892000
Aug 11, 2019 11:16 AM
Stryker412
Sep 20, 2015 06:59 PM
m00n420
Sep 11, 2015 02:39 PM
Accerrito22
Sep 5, 2015 09:34 PM
Out-Cast
Canadian Region
Sep 4, 2015 10:13 AM
