L98 Horse power????
Car: IROC-Z
Engine: 350 VORTEC
Axle/Gears: 4.10
L98 Horse power????
L98 motor
horsepower tork
245@4400 345@3200
if i put shorty header,an a cat back hooker system, with a aftermarket Y pipe, with a mild cam, flat top piston bored 40 over, with MSD ignition. with a lil bit of porting done to the heads. what kind of horsepower could i git out of that???
horsepower tork
245@4400 345@3200
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: L98 Horse power????
Uhhh that is a very broad, speculative question. Cam specs? CR? Pipe sizing? Lots of additional info needed
Transmission: 4L80E/4L80E
Maybe 225 at the wheels.
Why are you boring it 0.040" over?
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I had edelbrock shorties, edelbrock alum heads, zz9 cam shaft, mini ram intake, 30lb injectors, 52mm throttle body and electric water pump, and a perfect tune, and only put down 292 to the rear wheels. So your going to need quite a bit more to reach that 300rwhp mark
sailtexas186548
Aug 24, 2015 10:11 PM
