3.42 GM motive gears installed and ABS LIGHT is on
Hello all,
I have a 1995 Camaro Z28, I have swapped the original 2.73 gears for 3.42 gm motive gears, ever since I have done that the ABS light goes off and on, I looked inside the diffential and the abs reluctor wheel is not directly under the sensor, it is about half way on the sensor. Is there any type of spacer that I am missing, the gears are quite and care runs great, but the abs light will not go off. Please any advice would be much appreciated.
Here is the part # GM MOTIVE 3.42 gears - 26026835-41:12-7 5/8
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: 3.42 GM motive gears installed and ABS LIGHT is on
Hello all,
have you tried posting on ls1tech, they may have better answers...
try the following link...
http://www.ls1tech.com/forums/search...rchid=10630952
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
