88 l98 vette engine questions
Old Mar 30, 2010 | 09:24 AM
gta007's Avatar
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
i did a search and didnt find the info i was looking for. I am in the process of transplanting a 1988 corvette L98 in to my 1982 trans am. My question is: does the factory cam have the provision for a manual fuel pump? At this time I want to keep my carb set up. any direction would be great. thanks
Old Mar 30, 2010 | 09:31 AM
88gta3508's Avatar
Car: 00 SSEi / 94 C4
Engine: 231 / 383
Transmission: 4T65E / ZF 6sp
Axle/Gears: 2.93 / Dana 44 3:45
Re: 88 l98 vette engine questions
Yes the L98 cam.. has the fuel pump lobe..if you chose to retain your Carb setup..
you will need to look at the block... many blocks were not drilled out.. to accept the fuel pump rod....
Old Mar 30, 2010 | 11:52 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
88GTA is exactly right on!!!!!!
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
matthew911
Aug 12, 2015 09:38 AM
