Distributor leaks oil??
Old Mar 31, 2010 | 08:02 PM
MADMAXGTA's Avatar
Car: 89 TTA
so,I found my plastic trans cover was a bit oil dampened,and I traced to sorce to my distributor?!! wtf? left a little puddle right under it,on top of the intake.did not know they could leak.I was advised to replace the whole thing.
I havnt removed the cap yet to see if its wet under there .
Old Mar 31, 2010 | 08:48 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Re: Distributor leaks oil??
Doesn't sound right at all. You definitely need to pull the cap and make sure you dont have oil somehow making it's way in there...it shouldn't even be possible for that to happen really.
If it's leaking from the base that's simple enough, yank that sucker out and replace the O-ring. 5 minute job, 3 dollar part.
Old Mar 31, 2010 | 09:49 PM
MADMAXGTA's Avatar
Car: 89 TTA
Thats what I was thinking.
Old Apr 2, 2010 | 05:29 PM
MADMAXGTA's Avatar
Car: 89 TTA
yea its weird but true,pulled the cap and its soaked on the inside?! time for a new distributor asap.
Old Apr 4, 2010 | 12:50 PM
MADMAXGTA's Avatar
Car: 89 TTA
Replaced and everything is fine,just blows my mind that a distributor could leak up and out the shaft.
Old Feb 28, 2012 | 07:44 AM
86monster's Avatar
Had the same problem, thought it was just a top end intake leak until i realized the distributor has an o ring near the top of the shaft and when that gets worn down oil just pisses out the top
86CamaroDan
Sep 29, 2015 10:08 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
